Certified Firmware for AirGradient ONE Model I-9PSL
#### Please note This is the AirGradient certified firmware blob which is closed source and has fewer features than the open-source firmware available here.
Please note
Use this version for official purposes, e.g. co-location tests.
This firmware is only compatible with the Version 9 of the AirGradient ONE.
Please follow these steps for flashing:
- Push the reset button and keep it pushed. The button can be pressed with a small screwdriver through the small hole at the back of the monitor.
- Plug in the USB C cable into this computer
- Release the button. If you do not do this, the board will not get into the flash mode.
- Press this blue button
- Select the serial port your monitor is connected to. It is typically called “USB JTAG / Serial Debug”
- Click on "Install AirGradient ONE (I-9PSL) CS Firmware"
- After the flashing is complete, restart the monitor by unplugging the USB C cable (and plugging it back in)
